2006 M35 cam sensor
cfrankling
Car: 2006 Infiniti M35
Hello,
2 days ago, got the "check engine soon" light on with VDC/Slip light while driving, headed to autozone and checked code and it turns out to be the Bank#1 cam sensor, OEM cost is around 140.
Any alternative brand that may be a bit less expensive and good enough for my beloved M or don't risk it and bite the bullet with OEM? Tight budget right now after daughters wedding.
After doing so investigation, it seems that it is not that complicate to replace, I may end up buying both sides/banks and replace them myself.
Thanks for the info.
Carlos
EdBwoy
Did you by any chance get a quote at Autozone while there? Some people say OEM is preferred, but I have had decent luck with a few Duralast sensors.
cfrankling
No I did not but will do. When you say "decent luck" what does that mean edbwoy?
How much did you buy them for?
EdBwoy
I meant that I've never had a Duralast (Autozone house brand) sensor fail me. Autozone locations are plenty and I can do a warranty swap easily if need be. I won't buy a no-name aftermarket brand online.
My experience has been with other sensors for previous cars, but IIRC the prices were never more than 40 bucks for these drivetrain sensors.
cfrankling
Oh I see, ok will check with local autozone and compare prices with OEM.
Thanks for the info EdBwoy, very much appreciated,
Sstupid
Car: 2007 Infiniti M45 Sport
I have a thread on this. The Duralast brand costs more than I found the OEM part for. I found out that the Nissan Xterra or Rogue or some SUV’s crankshaft sensor was the same part and cost less than the Infiniti part. I’ll try to find the thread.
Sstupid
It’s on page 6. Look for P1140 code in title.
cfrankling
Thanks, bought one for $80 at OReilly with lifetime warranty, its good now, car runs great.
yomoms16
Car: infinity m35 x
I changed both cam sensors in early September. With sensors from rock auto
even after seeing numerous post online saying how aftermarket sensors with nissan engines is a hot or miss
Fast forward 5 months later car keeps stalling. Hard to start and even cutting off whilst driving
pull engine code. And yup sensors again
Just do it right the first time and get the sensors from the dealer. It's like $90 a piece plus shipping. Discount infiniti parts online. Dealership in GA I live in Both Jersey and get shipment in 2 days maybe 3 sometimes
