2006+ M35/45 Bulbs
S_Klass
Car: 2006 M35 Sport - Optioned Out!
Hello,
I'm the new guy! Going to take delivery of a 2006 M35 Sport in 2 weeks and want to do a full LED swap.
I've gone through the FSM and have questions on the bulbs as the FSM doesn't describe the bulbs in standard fashion (H7/168/2825 e.t.c.)
ExteriorF. Combination Lamp - Front Turn Signal - 7440A - Qty 2? (Is this bulb the furthest from the grill?_F. Combination Lamp - Parking Lamp - 2825 - Qty 2? (Where is this bulb? Does this serve as M35 DRL? Is this constantly lit?)F. Combination Lamp - Front Side Marker - 2825 (Do I need Flank Mount*?) - Qty 2?R. Combination Lamp - Stop Lamp - N/AR. Combination Lamp - Rear Turn Signal - 7440AR. Combination Lamp - Rear Side Marker - N/ABackup Lamp - 921Side Turn Signal Lamp - 7440A (Do I need Flank Mount*?) - Qty 2?Front Fog - H11 License Plate - 168 (Do I need Flank Mount*?)High Mount Stop - N/A
InteriorMap Lamp - DE3175 or BA9? - Qty 2? Where is this bulb?Personal Lamp - Type? - Qty 2? Where is this bulb?Trunk Room Lamp - Upper - 168? (Do I need Flank Mount*?)Trunk Room Lamp - Lower- 168? (Do I need Flank Mount*?)Front Ashtray - Type? - Qty 1?Rear Ashtray - Type? - Qty 1?Step Lamp - 158? - Qty 2? (Do I need Flank Mount*?)Vanity - Type? Qty 2? (Do I need Flank Mount* or Festoon?)Center Console Indirect - N/AGlovebox Lamp - Type? - Qty 1? (Do I need Flank Mount* or Festoon?)Foot Lamp - Type? - Qty 2? (Do I need Flank Mount* or Festoon?)
*Flank Mount bulbs are bulbs where the light is cast perpendicular (90 degrees) to the mounting of the bulb.
A lotta questions, I know. Sorry but I'm really excited and can't really wait.
Thanks!
jermiechan
Car: 2008 M35 AWD
Hey S_Klass,Do you know how to change the License plate light bulbs?
S_Klass
The FSM has instructions, IIFC, looks quite straight forward to me.
But that's for the 06-07, although it doesn't look like it should have changed.
Refer to LT and then page 265.
