2006 Infinity G35 jerk ( jump ) from neutral to drive !
Gmoney35
Car: 2006 infinity G35 sedan
2008 infinity G35 coupe
:wtf2: :wavey:
Does anyone know what could be wrong with my G35
It will ( kick/jump/jerk ) not only while it’s cold
And only from neutral to drive
Car shifts smooth but stays at high RPMS
40 mph its at 3pms 80 mph 4-5 rpms
Can someone help please !
Thank you
telcoman
Your problem is because you do not know how to spell Infiniti
Telcoman
Gmoney35
Hey telcoman if you’re not of any help why are you on this forum ?
picoman
Car: 2006 M35X
The quick easy things to check are
-Is the idle speed correct? It should be 650rpm or so at idle. if it is significantly higher then you should do the idle/throttle position relearn procedure
- Are the engine mounts bad/leaking fluid/cracked
- I personally would change the transmission fluid, and only with Nissan Matic. I have felt the difference in smoothness first-hand vs Castrol transmax which claims compatability with Nissan Matic.
There are other transmission related things that would require connecting it to Consult to diagnose.
I am in no means an expert but those are the first things I would check.
