I just bought a 2nd 2006 M45
First codes:
10/2/19 - P1140 Powertrain
10/2/19 - P0430 PowerTrain Catalyst System Efficiency below threshold (Bank 2)
Then I moved the 2 top Camshaft sensors (or crankshaft if thats the top ones, easy to reach) from my fully working and good Brown 2006 M45 and then reset the ECU (doing the 5 hard presses, and 10 second hold down and such)
Then 2 new codes popped up
10/6/19 - P0011 PowerTrain "A" Camshaft Position - Time Over-Advanced or System Performance (bank 1)
10/6/19 - P0021 PowerTrain "A" Camshaft Position - Time Over-Advanced or System Performance (bank 2)
So I put the 2 old sensors back in and got the original codes again
10/14/19 - P1140 Powertrain changed sensors back
10/14/19 - P0430 PowerTrain Catalyst System Efficiency below threshold (Bank 2)
so then i just moved the bank 1 (passenger side) sensor
10/14/19 changed bank1? - passenger camshaft sensor
10/15/19 - P1140 Powertrain instantly get this one - after both the odb reader ecu reset, and the reset procedure.
10/15/19 - P0021 PowerTrain "A" Camshaft Position - Time Over-Advanced or System Performance (bank 2)
Today I'm thinking ill switch the timing solenoid between the cars (the one shown in this video: https://www.youtube.com/watch?v=aoDA4BgYGGk)
I'm just trying to troubleshoot if/what part is bad
Yesterday (10/15/19) I changed the oil just to make sure the oil was good.
Anybody have any ideas on what the issue is here? When put the silver cars camshaft sensors into the brown M45 the brown never threw codes, so I assume the camshaft sensors are fine. So now trying to troubleshoot other parts. Just confusing me how I have 4 different codes, all depending on what camshaft sensor I have in the silver car
My annoying time constraint here is Utah will only give me 1 additional 15 day temp registration, so after 15 days from now i'm in trouble :P - since I can't pass emissions with the CEL on
