LouCast »
https://forums.nicoclub.com/loucast-u222990.html
Fri Feb 14, 2014 11:57 pm
The code is for a number of things. Radiator fans not turning on and off like they should, thermostat not opening, radiator blockage, and so forth. Now by what you stated in your second post, you let it warm up without driving and everything looked fine, but it started to over heat when you went for a drive. I have seen this once, it was on my old Nissan Armada, and it was a blockage in the radiator, it is something that Nissan product suffer from. Most Nissan vehicles do not have a spring on the radiator cap, cause the pressure releaser is on the overflow tank. I have not looked to see if we have a spring on the cap. Have your system flushed, and change the thermostat. If it continues to overheat, then I suggest you start looking for a new radiator. I speak from my own experience, and this may not be your situation, but rather an avenue where you can start looking at.
