Not sure how much camber my rears have, both the front and the rear tires wear from the inside. the tire kinda sticks out of the side a little tiny bit and when i go over a bump and theres ppl weighting the back end down it rubbs to hits the the fender or quite possibly the liner but i think its might be the fender though. Im going to try the alignment if that doesnt help probably get the rear wheels machined a bit. Also just going to lower the front of the car with h tech springs.mexillis wrote:Do you know how much camber you rears have? Or are you saying f/r wear from the inside? If your camber isn't negative at all you might just need another alignment and actually camber in the rears. That could help with your rubbing issue. If that desnt do what you need look into pulling or rolling your fenders. Are you sure its rubbing the fenders or is it rubbing the carpeted liner? Lastly you can lower just the front if you want, it wont hurt anything
OK Thanks! I want to smoke my tail lights out as well just not as dark also... How much $$ Also, the grill does look like the midnight black INFINITI grill. Mine has chrome and black in the center part! We gotta get together... I'll be taking a week off after this coming Saturday so I'll have plenty of time. Not going to do much except some spring cleaning so hit me up you know the number ok!!tbelcher wrote:Thanks Bodyguard, I got the new tires in this past week. I had my tail lights painted (smoked) at a local shop. They turned out a little darker than I hoped but the quality is very nice. I'm not sure which grill, I do know it was OEM from Nissan but black instead of Chrome.
You ever get some pictures so we can see what you're talking about?? Did you fix your problem??06M4.5 wrote:ok post some pics so that we can see
