+1marlin29311 wrote:Air fliter, tire inflation, driving habits, gas type, etc....
It could be a world of different things - I would start by looking at the simple replacements - air filter, etc, and see what happens from there.
I had one car with a gas leak on the discharge of the fuel pump. Wasn't obvious since it only occuring with the engine running and it pointed straight at the ground. Amazing how much a pinhole gas leak adds up in gallons.marlin29311 wrote:Air fliter, tire inflation, driving habits, gas type, etc....
I have an 08 xs. I get between 19 and 21 on an average depending on the weather, real cold and it is on the lower side.catsnmusic wrote: His first recommendation is that even though my manual for the sedan says the car takes 87 octane (coupes require 91 for some reason), he said try bumping the octane up to 89 or 91 and see if my mileage improves. He said also instead of warming the car up for 15 minutes every morning drop it down to 10 minutes. He said these two things should help. How does all this sound to you veterans on the board?
Today I made a trip from Rainier, Washington to Lacey, to Shelton, to Bremerton, then to Port Townsend. On the way there I averaged 50.2 mph and got an average of 25.1 mpg. Temperature about 45 most of the way. I was actually a little surprised.kmckis1029 wrote:my last combined mileage was 19 mpg... and thats with spirited driving... i measure the same way the infinity tech did...
That is good to hear. As far as cruise control goes, most experts would state that it will hurt your mileage if the desire is maximum mpg rather than speed maintenance. I still use mine and let it follow the car in front of mine automatically maintaining distance in good weather conditions. On the other hand I am not yet a hyper miler, although I am tempted to try a few sessions with the car to see what actually is possible since we have the tools already installed.zozoka1212 wrote:Yeah there is nothing wrong with our G. It is just warm up time city driving.
Last few weeks I've got like 13-14 mpg but I drove less time than I warm up my car. All city and short runs.
I went to Toronto 2 times this weekend back and for and ended up with 23.5 mpg. I pushed her few times. Was not using cruise controll and was never steady on the gas. Was going between 70-90mph. Sometimes less sometimes a little more. There was about 10 % city driving.
I have the laser cruise control in my 08 Infiniti XS sedan. I like it a lot with the exception that it appears to be a little sensitive when following another car. I wonder if that can be adjusted somehow. What it does is sort of pulse when following unless set at pretty much exactly the same speed as the car in front. In normal mode at slower speeds it tends to hunt a few mph at times but smooth at higher speeds. My 1999 Chrsler on the other hand maintains pretty much right at the set point up and down hills unless it is forced to downshift to maintain. At that time it hunts a little before settling down. The G tends to fluctuate more.Poyzinous wrote: If your Infiniti has ICC, you're a lucky son of a Bi--ssnessman. ICC is wonderful. Anyway, if your car has bad MPG, make sure you aren't riding your brakes, sometimes people leave the parking brake(not E-brake, gosh darnit) on a little, or in the winter with the heat running, leave the AC on(I always turn it off), low tire pressure, obstructed intake/exhaust due to leaves, rust, curious animals, water, smurfs, etc. I only get 16mpg out of my G35x. But I have a heavy foot, and I'm mostly driving city. On a recent trip, I went a full 400 miles on one tank. With 3 people in the car, lots of luggage, and 70-75mph average speed on the highway.
