kmckis1029 »
https://forums.nicoclub.com/kmckis1029-u103545.html
Thu Apr 25, 2013 1:00 pm
spark plugs on your car are at the end of their life (they last about 100k miles) if they haven't been changed already.
also you might what to change the front and rear differential fluids if that hasnt already been done in the 88k miles, its as easy as doing a oil change. (just with a horriable smell)
consider induction cleaning with base idle reset and/or running some fuel system cleaner after you have fresh plugs. (easy base idle reset is to leave battery unpluged and hit brakes a couple times)
then lastly id upgrade your transmission fluid to matic S, if the transmission fluid hasn't been changed within the 88k miles.
should be a nice boost in milage with fresh fluids, spark plugs, induction/fuel system cleaning/idle reset, and air filter replacement.
