2006 g35x P2A03/P2A00 after changing downstream o2 sensors
si2ki30
I was getting P0420/430 DTC codes (cant remember which side), so I replaced both downstream o2 sensors with A-Premium sensors from Amazon.
The P0420/430 codes went away.
Now, I was getting P2A03(b2s1) and P2A00(b1s1) for both the upstream A/F sensors. I tried all the relearning procedures and used injector cleaners/fuel cleaner, etc.
Still getting P2A03/00
The upstream sensors are harder to get to, so I avoided touching them for a while.
Just replaced the driver side upstream A/F sensor (b2s1) with Denso 234-4302, cleared codes, but then after a little while P2A03 came back for this side, as well as P2A00 for the passenger side (still using old sensor)/00.
I've never had the intake taken apart and I checked for intake leaks with a smoke tool, and havent found any.
Any ideas?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The front sensors are 1.5V widebands, I have a hard time imagining one of them went bad just as you changed the rear O2's. The ECM does use the rears as a feedback check for the fronts, so I'd say your new bank1 rear is probably crappy.
si2ki30
VStar650CL wrote:
Mon Jul 13, 2026 8:17 am
Just put in an order for a Denso left downstream sensor, will report back when installed.
