2006 G35 Sedan interior lights
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
Rooster Cogburn
Car: 2006 G35
I read on here that the lights for the g35 are all 165/194 type. I bought a lot of 10 (194) wedge style LED lights to replace mine. They fit fine in the license plate but they don't work for the interior lights. The interior lights use a round cylinder style bulb with metal ends. The metal ends snap into a clip on each side.
Does anyone know a way to get the wedge bulbs to work? adapter?
What is the light # for the interior cylinder lights?
Thx.
silvee811
Car: 2003 Infiniti G35 Desert Platinum 5AT 4dr
there are 6 interior lights, 2 map lights, 2 front door runner lights, and the 2 back seat lights. all 6 use the same 30x10mm festoon bulb. check out this website
http://www.superbrightLEDS.com
I bought the ones with 4 LED in white for the door runners and the back seat lights and the 9 LED for the fron map light. they are easy to change out, just use a flathead screwdriver to pop out the plastic casing over the bulbs.
They also have it in available in UV blacklights too which i wanted to use for the back seats, but itll bug me that it wont match the other 4 interior lights that i want to remain white.
the thing when you change the door runner lights, they are on (unless theres a way to shut them off while the door is open). So be careful not to burn yourself when popping them out and handling it.
I did mine this morning and it looks sweet!!
Q451990
Rooster Cogburn wrote:I bought a lot of 10 (194) wedge style LED lights to replace mine. They fit fine in the license plate
Are they as bright as the OEM bulbs?
Heath
Return to “G35 and G37 Interior, Exterior and Audio”
