mikeatx »
https://forums.nicoclub.com/mikeatx-u44730.html
Mon Aug 07, 2006 9:29 am
Since its new, you might wanna take it easy on the motor for a week or so anyways. There isn't a breakin period like the old V8s needed, but its still good to baby the motor for the first 500 miles or more.
The brake pads would have had a very strong, unique smell if you got them too hot. Alot like a burning clutch if you've ever smelled one. Its aweful.
Could also be something that was put on the car when it was detailed or if you had a protective coating put on. Anythink on your discs can cause smoke.
Or you just simply got them too hot. If they feel fine and are still quiet, then your fine. I burned up a set one day on an Integra and they never ran the same. Ended up replacing all 4 the following week.
Coming to a complete stop as quickly as possible from 100+ is quiet hard on any brake pad.
