float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Thu Mar 27, 2014 5:26 am
You could try playing with oil viscosities and see if it makes a difference. If it's just the tensioners, that's a big job, but not a reason to sell the car. If changing oil viscosities doesn't help, chances are the low oil has damaged a main/rod bearing. If that's the case, you're on borrowed time. As long as you keep it full, it won't get worse, but it's still probably damaged and the engine would have to be rebuilt/replaced.
