jerry119 wrote:I have a 2006 Coupe with about 112K miles, auto trans, that I bought used about 6 months ago, that started overheating. No external leaks but will overheat after about 45 minutes - 1 hour of extended highway driving, overflowing coolant into the overflow tank and pulling it back into the radiator after cooling down, usually requiring adding coolant to the overflow tank. Will not hold pressure when the cooling system is pressurized. Does not use coolant or overheat when driving in the city - only on the highway at continuous speeds. Never overheated badly to my knowledge. Does not appear that water is getting into the oil. Took it to a local dealer suspecting a warped head or bad head gasket. They want $3500 to replace head gaskets, or as much as about $15k for a new engine, but they are not really sure to what extent it is damaged (may be a block problem too). My thought is to buy a used engine for same or less money. Ideas? Would a newer G37 engine fit without serious problems - accessories, trans, etc? The car is almost worthless without an engine and I still owe on the loan. HELP! Thank you...
Did the dealer perform a compression test to confirm a leaking head gasket?
Was the water pump, thermostat, and fans tested? What about a loose belt?
Try another dealer for a second opinion
Good luck
Telcoman
