2006 ARMADA LOW BEAM REPLACEMENT
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
MIGALONE
Car: 2006 NISSAN ARMADA
My low beam went out. there is one screw holding the assembly at the top when you open the hood. After i removed the screw, the assembly did not seem to want to come out. i dont want to take it to the dealership to be drug over the coals for a part i just bought to replace>Can someone please help me???
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
The low beam should be access by turning your steering wheel to one side, and actually going underneath via the wheel well. there is a black plastic cover that you will need to remove I believe about 3 screws, and 1 screw with a hex head on it. Let me know if this helps.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
