2006 Altima AC causing skips/bumps while idling
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
Warreng76
Car: 2006 Nissan Altima
Looking for some input: when my Altima is idling in drive with the AC on it continually "bumps". I'm not sure if this is the AC causing the engine to skip or something else. Just need some pointers on what to look for that could be the cause. The air gets cold and the blowers and fans work; there are no problems while idling with the AC turned off; the engine doesn't idle high. The skips happen more frequently when the car is in drive but it occasionally happens also while in park.
Thanks!
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Could be a bad compressor clutch or pulley, causing uneven load.
darylzero
Car: 2026 Toyota 4Runner Sport Premium
Previous-Nissan Rogue 2009 SL AWD Premium Pkg.
maybe the belt has too much slack and needs to be replaced.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Moved to Altima forum.
Warreng76
Thanks, I'll take a look.
Return to “3rd Generation Altima Sedan (2002-2006)”
