2005 xterra
Jsalko
Hello,
I've been trying to fix my 4-wheel drive problem for awhile now with no luck. At first it was pic-gram was blank but replacing the relays under the hood fixed that problem. Now my next issue is I'm not getting power to my actuator motor. The actuator motor does work as I've manually tested it. I've tested the switches on the transfer case and they all work. I've even replaced the "black" switch as that deals with 4wd. I'm still unable to get power to the switches or the actuator motor. I've traced the wires and nothing looks cut. Does anyone know where the power comes from to that area? I did replace the heater core as it was leaking which did get the wires/harness plugs along the passenger side wet. I took the plugs apart and cleaned them but I'm not even sure that deals with the actuator harness at all.
Thanks
John
Q451990
:welcome: to NICO John!
I don't have anything specific for your problem, but if you haven't found the factory service manual for your X - you can view/download it at http://www.nissanservicemanual.com
There should be a good breakdown of how power is supplied to the actuator there.
