Marcellus »
https://forums.nicoclub.com/marcellus-u272038.html
Tue Feb 28, 2017 6:31 pm
I tried the fuses and changing the front blower relay. This van is supposed to have a resistor, but from what I read, the resistor is an issue when the blower only works at max speed. My blower does not work at any speed.
I remember that during last year, the blower would cut out suddenly for a few seconds and fire right back up as if nothing had happened. This would happen a few times a week, I just learned to live with it. I guess that the brushes on the blower were wearing out. I am thinking of opening the dash up, take out the blower (I heard it is a b**** to do) and I might as well change the brushes on the motor. The fix would cost less than $10 but the labor to remove/install the blower is supposed to be difficult. I could test the blower prior to removal if I can get a 12V wire into it and see if it turns, just to make sure the problem lies with the blower.
