2005 pathfinder won't start
kneumeier
Car: 2005 Pathfinder
I have a 2005 Pathfinder with about 90,000 miles. It has been a good car so far. About four months ago the fuel level sensor went out. I still need to fix that. The check engine light started coming came on a couple months later and now stays on. About a month ago we were driving down the interstate and it started to die. RPM's went to almost zero. I pulled over and it was idling very rough. I turned it off and waited about 30 sec. and it started right up like nothing was wrong. Drove it for a few hundred miles and it did it again. It got more common over time, about twice per tank of gas. And recently it has become very common and harder to start. Now it will not start at all. I have replaced both camshaft position sensors and made sure the fuel pump is pumping fuel. It is flashing codes P1446, P0463 and P0430. I have talked to two dealership service departments. One said cam position sensors and the other said catalytic converters. Now I see something about the IPDM. Can you tell me what is wrong or what to look at to figure out what is wrong so I can get this back on the road? Thanks!
