sw.millington wrote: ↑Sun Jul 11, 2021 7:20 am
I think it's an electronic issue, like the (anti-theft) vehicle immobilization system. But this should show up on an OBDII scan shouldn't it? I think maybe a module has bought the farm. I have been reading manuals and trying to find a solution for over a month now, and really don't want to replace the vehicle just yet. I'm really looking for any experience out there with this problem?
Thanks for clarifying. Yes, no-crank is different and a security issue won't cause it. Security would let it crank endlessly with no spark, and there would be P16xx codes in the ECM. The starter is directly activated by the IPDM and the TCM, so a test lamp will tell you where the problem is. Here's what you'll need for diagnosis.
Begin your diagnosis with Gray wire terminal 21 on the IPDM. With the test light grounded, probe 21 while turning the key. The lamp should light. If it doesn't, you probably have a bad ignition switch. If it does, probe White wire terminal 19 while turning the key. That wire goes direct to the starter solenoid, so if it lights with the key then you most likely have a bad starter. If it doesn't light, connect the test lamp to 12V instead of ground, then probe terminal 48 Red while turning the key. If it lights then you have either a bad starter relay or a bad IPDM. Obviously try a relay first. If it doesn't light, it means either the trans controller (TCM) is offline or the neutral switch is bad. Check the transmission fuse first (also in the IPDM).
