2005 Pathfinder Hose Help
MFS1589
All,
I am trying to identify an air or vacuum hose that has come loose on my 2005 Pathfinder.
It is located on the driver side, the lower end is attached at the bottom of the engine, well below the oil dipstick. It is not a fluid hose, seems like an air or vacuum hose.
Trick is I cannot figure out where it should be connected to. I have search countless diagrams but cannot determine what hose it is...
Thanks for any help you can direct my way...Image
robbykennedy
Car: 2003 Pathfinder SE
2005 Mercedes Benz C-Class
Can you post pictures so we can see?
