2005 Pathfinder Engine Noise....after 2k RPM
NCturbo75
Car: 2006 INFINITI M35...
I was wondering if anyone else have this issue. For some odd reason, I would hear like a rattling noise coming from the engine bay when I rev between 2k & 3k RPM. It sounds like something is loose or something. I have checked and there seems to be nothing out of the ordinary to be wrong. Any help would be greatly appreciated. BTW, my Pathy has over 43k miles on the odometer.
nismodatsun
Car: 2005 Nissan Pathfinder, 88 Honda Prelude Si, 99 Honda Civic LX
Ive got the same issue. Any word on it?
NickD85
Car: 2001 Infiniti Qx4
have you checked the heat shields on the exhaust and catalytic converters? They tend to rust out, come loose, and begin to rattle over time.
Pwnin O'Brien
NickD85 wrote:have you checked the heat shields on the exhaust and catalytic converters? They tend to rust out, come loose, and begin to rattle over time.
What he said.
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
More specifically the heatshields are usually the culprit also
NickD85
miamiheat3332 wrote:More specifically the heatshields are usually the culprit also
I mean, I said check the heat shields on the cats and exhaust, so saying "the heatshields" would actually be slightly less specific
nismodatsun
I haven't had a chance to look under the car or under the hood, but I did find a TSB about it. I will post the tsb # later.
nismodatsun
Ok, here is the bulletin
NTB05-015b
here is a link to a xterra website with the same problem and discussion of bulletin.
http://www.thenewx.org/forum/s...15812
PM me if you want me to email you the PDF, I don't know how to paste it in here to work or if you can.
