Just went to the garage (it's 9:19pm here) and I just checked. Sure enough, there is a nut accessible from the bottom. I already had the wheel well inner cover off, so I could easily see it once you pointed it out. I'll spend some time tomorrow to undo that, lift the box and remove the pipe and hoses out.VStar650CL wrote: ↑Fri Feb 19, 2021 9:27 pmIt isn't difficult. Since your old reservoir is trashed, you won't need to worry about getting the bottom hose off it without breaking anything. The hose on the lower nipple is clamped, you can just cut the old one to make the end of the metal pipe easy to get at. Three 6mm (10mm head) screws holding the reservoir in, if memory serves there's one at the base and two on the inner fender. If you want to get underneath the boxes to replace the pipe, you'll need to peel back the rear portion of the wheel well inner cover, there's a 6mm nut on a stud that holds the main box in from the bottom.
Just a helpful tip, soaking those clips with a little WD40 or PB Blaster before removal makes them a lot less likely to break. It's dirt in the channels that binds them up. Same applies to the latches on electrical connectors in exposed locations.
Good idea. As of yesterday, I only put WD40 on the metal clamps to help push them back on the rubber.VStar650CL wrote: ↑Sun Feb 21, 2021 5:28 amJust a helpful tip, soaking those clips with a little WD40 or PB Blaster before removal makes them a lot less likely to break. It's dirt in the channels that binds them up. Same applies to the latches on electrical connectors in exposed locations.
