O5Q45 »
https://forums.nicoclub.com/o5q45-u267923.html
Mon Dec 25, 2017 9:33 am
I purchased the most "liked" thermostat on Rockauto web site.. It was not a Nissan t stat. It was a safety t stat that was or is, supposed to stay permanently open after an overheat.. I had the t stat replaced by this unit with the radiator and the Nissan coolant. (Green). 30,000 miles goes by, and last month I had the Nissan Coolant replaced with new.
The reason I was idleing at 2,000 rpms is because there are several roads in my area that cause the middle of the car to scrape some. My wife also visits a patient with a driveway that desends to the depths of hell.. let's just say steep.. the car will not reverse up the driveway even when dry without wheel spin.. and so you can imagine at the top where it meets the roadway.. this is also one of several scrape areas.. last time upon pulling out she managed to run the passenger rear wheel over a curb in same driveway and absolutely destroyed the metal protective skid plate over the fuel and brake lines.. somewhere around then and the full slow/no pressure transmission flush, the car has vibrated and ran rough accelerating through 1/2 2/3 and stops vibrating in 3rd.
I ordered the bluedriver OBD2 Bluetooth code reader and have been monitoring several systems.. the car runs around 190-200 degrees since I started monitoring. I guess that's normal.. however, the other day when I pulled in I looked down at my phone and saw 204 degrees. I popped the hood, coolant reservoir at correct level, and began running 2k rpms. I watched the info I was receiving from the ECU to my reader, and watched the temp climb to 250 degrees and cut off the engine. I heard no boiling, radiator cap still sealed.. when I returned the next AM, it took the motor around 2 to 3 times longer to start but did. My driveway is wide open space..
This morning it was 24 degrees, and I went out and started the car to warm up because I Don't trust the misses to drive it proper with a cold motor or transmission.. so, monitoring from the living room, the car idled for about 15 min, and never got above 165 degrees before she left.. so, I'm guessing maybe the t stat is locked open... Yes, both fans were on. I believe the secondary came on around 206-210.. sorry for the book.... But that's how it all came together...
