2005 Nissan Titan
ryreen2002
Car: 2005 Nissan Titan
I got into my Titan and started is as normal. I then place the transmission on Drive and press the accelerator to move. Just as the truck was moving forward, the engine dies.
I then placed the transmission on Drive mode again and did the same thing. Same results, the engine dies. I then started it again and pressed the accelerator and noticed that the RPM goes up to 2 1/2 RPM and notice that that engine starts to miss fire but still stays on.
I then place the transmission on Drive mode and tried to go but the engine died again. What do you think is the problem?
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
fuel pressure would be my first guess. Clogged filter is the quickest and easiest thing to check.
Any check engine light? If so, get a code reader and go from there.
