Haha, I am completely new to this kind of thing and have absolutely NO clue what you are talking about with the "45 series" and "40 series"b15chik wrote:i have 18's they fit fine. you will just want to roll the rear fenders.
i also have the falken ziex tires, they're all seasons so i'm not sure if that would work out for you up there. not terribly grippy though. although they have lasted me quite a while.
the problem with going to low of a sidewall on the tires is that it's easier to bend the wheels. if you end up going with a 17" wheel i'd say stick with 45 series, and if you go with 18" do a 40 series.
depending on the width of the wheel you'll probably want to do around a 215 or 225
Ok,then I pick price and style because that is the two things that I want.nametakennow wrote:So you want quality, price, and style? Sorry, pick any two.
Haha, more seriously though, the Sentra would look funny with rubber-band tires.
40/45 refers to the tire sidewall "height" if you will, while the 215/225 bits refer to width.
So, when someone says 215/45/17 (what I run, for instance), it's 215mm wide across the tread, 45mm thick in the sidewall, and has a 17in inner diameter.
That looks something like this:
Note: My car is lowered about 1.5in, and those obviously aren't stock brakes, though they are stock size.
