We replaced the battery on the car, cam sensors, then the alternator and now the wiring. My mechanic said the battery is showing the correct voltage but the amp is too low, which is causing issues. AutoZone claims the battery is fine because the voltage is fine, so they refused to replace anything. As I drove it home from AutoZone it began it's original issues, it pauses and has no acceleration. Once I put it into neutral it allows me to rev the engine, then switch back to drive (once rpm is down) and it'll drive for a bit. My mechanic is still saying the battery is the issue and will check it later tonight.
Is there anything, outside the battery, that needs to be checked or could be causing these issues?
