2005 Murano alignment specs????
Forum for the unique Murano, and official home of Nissan Murano Club!
silvernblack
Car: 1989 Nissan D21 pickup
I'm going to attempt to do my own alignment. Anybody have the specs for alignment? My right front tire is developing some inside wear. Doesn't pull or anything but I suspect Camber might be off.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
You can find the front wheel specs on FSU-16 here...
https://www.nicoclub.com/service-manual ... %2Ffsu.pdf
...and rear wheel on RSU-18 here:
https://www.nicoclub.com/service-manual ... %2Frsu.pdf
There's no native camber adjustment on the front wheels, you'll need to install a camber-bolt set on the front struts.
silvernblack
No camber adjust eh? well.... that'll throw me a twist! I'll check and see what's going on.
Where would I acquire one of these camber bolt setups? I should plan ahead....
Thanks.
VStar650CL
Technical Expert
They're all over eBay and Amazon. They're just eccentric bolts which replace the two plain bolts on the knuckles, allowing the knuckle to be tilted relative to the strut flanges.
silvernblack
thanks. I'll go look around. Wow! Found them immediately! I attached a link but here is the description for when it dies:
"TRQ Suspension Camber Adjustment Bolt Kit LH Driver RH Passenger Side Pair 2pc"
Many thanks
https://www.amazon.com/TRQ-Suspension-C ... san+Murano
Return to “Murano Forum”
