2005 Infiniti QX56 Do I have satellite radio?
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
phoenixta
Car: 2005 Infiniti QX56
Sorry this is probably a silly question, but do I have satellite radio? I just bought a 2005 QX56 and I have the button for SAT RADIO but I'm not sure what to do to make it work! How do I know if it's even installed? Is it possible to have the button but not the radio installed? Please help, thank you!
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
phoenixta wrote:Sorry this is probably a silly question, but do I have satellite radio? I just bought a 2005 QX56 and I have the button for SAT RADIO but I'm not sure what to do to make it work! How do I know if it's even installed? Is it possible to have the button but not the radio installed? Please help, thank you!
First off, WELCOME TO NICOclub! It is a pleasure having you as a new member of the Armada/QX56 Forum!
Here we go......you may or may not have the XM or Sirius receiver. The receiver would be located under the driver's side dash, mounted via aluminum brackets just above your gas and brake pedal. Here is a link to the Factory Service Manual http://www.nicoclub.com/FSM/QX56/This will show you EXACTLY where the receiver is located, if you don't have it, you will need to order a receiver, antenna, and I believe one other cable. I had to add the receiver to my '04 QX56 when I purchased and owned that vehicle. Pretty easy to do, I believe the whole thing cost about $350.
Let me know if you need any help!!!
phoenixta
Thank you! I'm going to check it out!
Return to “Armada Forum / QX56 Forum / QX80 Forum”
