Post by twodog35 » https://forums.nicoclub.com/twodog35-u294521.html Sat Mar 21, 2020 5:56 am
Post by Rogue One » https://forums.nicoclub.com/rogue-one-u185971.html Sat Mar 21, 2020 7:04 am
When the screen pops up, the upper limit is determined by the number of revolutions of the motor, not the actual position of the screen. Over time, this limit seems to go out of adjustment.
To "trick" the limit, while the screen is moving up, quickly press down or tap on the screen so it momentarily moves downward then resumes raising as soon as you let go of it. When done correctly, the screen should raise fully; if you hold it too long, the screen will retract.
Return to “G35 and G37 Interior, Exterior and Audio”
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
