2005 g35x creeking noise
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
stockade157
Car: 2005 infiniti g35x
I recently started hearing a creeking noise when I first use the car after sitting for a couple of hours. Seems to be coming from the suspension in the front as well as the rear. Last for first few hundred feet. Any ideas??Thanks,Jerry
dougiefresh7988
Car: 2005 infiniti g35x sedan
2008 infiniti g35xS sedan
does the car creek when you steer it ? if so it may be your pump or somthing mine is doing the same thing but i think it is nothinbg to worry about. check system fluid level
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
It could be compression rods in the front, rust, loose bolt/nut. Have the suspension checked by knowledgable people. Maybe take it to the dealer on your next oil change. The techs there would know very well what could be the issue.
Mainiac35x
Car: 2005 G35x
I get the same creaking noise in my '05 G35x w/45K. It happens (or is only audible) at low speed. I've been told it's coming from the control arm bushings and the way to tell is if doesn't squeak when it's raining. Mine doesn't squeak in the rain.
My question is, does this need to be addressed, or do I just need to put up with the noise?
Poyzinous
it can occur whenever. If it doesn't bug you, well then you can probably deal with it. If it gets louder or more frequent, yes, have your suspension worked on...
sexcpr69
Car: 2006 g35x
if i was you i would just get it done at the dealer you should still be under warranty i got my 06 35x new compression rods and they had to re torque the axels because it was clicking so i would do it before that expires
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
