2005 G35 won't crank
Headnsouth
Car: 2005 G35
2005 G35 150K miles automatic
Car has been great always reliable until now. Try to start and all I get is a electrical click under the engine cover. No click from the starter. Tried jumper cables NG same thing. No codes. Just ran into the store and came back out and bam no crank. I'm thinking starter relay or the starter. Any body had this issue? What can I check?
telcoman
Headnsouth wrote:
Sun Sep 13, 2020 10:58 am
What can I check?
Your battery!
Headnsouth
Car: 2005 G35
Nope! Tried jumper cables. NG Towed it home and threw the charger on it for a couple of hours same.
telcoman
Headnsouth wrote:
Mon Sep 14, 2020 5:02 am
Battery, Battery, Battery!
A dead cell will cause your problem.
Why don't you test or replace your battery?
Headnsouth
Car: 2005 G35
Load test was good. 12.6 SG
telcoman
Headnsouth wrote:
Mon Sep 14, 2020 2:34 pm
Assuming your battery cables are good, tight, with no corrosion your next step with a good fully charged battery would be to follow the troubleshooting steps in the FSM.
Anything get wet? Possible defective IPDM or the starter itself?
https://www.nicoclub.com/service-manual ... 005/sc.pdf
Good luck
Headnsouth
Car: 2005 G35
telcoman wrote:
Mon Sep 14, 2020 2:51 pm
Good luck
Cables are good and tight no corrosion. Hot and dry here in Ga. Thanks for the leads and link I'll check them out.
Headnsouth
Car: 2005 G35
Installed a new starter and bam we are back on the road. :)
Booman13
Car: 2003 Infiniti G35
Just replaced valve valve stems,seals and all timing kit , cant get car to turn over 2003 Infiniti G35
telcoman
Booman13 wrote:
Sun Nov 01, 2020 9:52 pm
Your battery might be dead?
Test it!
