Hello everyone.
So the car has some CAN bus issues whenever I go through the car wash, which results in drivability issues and dash lights and codes...but when the car is dry, there is no drivability issue and no dash issues and the car shifts fine.
What I noticed when I did a live feed from the transmission module (whilst trying to diagnose the above issue) was that one of the few speed PIDs (is that the right term?) would read like 140mph at a stand still and the other pid would read 0 at a stand still....then when I let my foot off the brake the two readings would make sense. The speedometer would read correctly
The car is at a shop that I hope can figure out what module or where on the can bus is water getting to, to completely wreak havoc on the bus. He too found the same weirdness in reported speed on his scanner. I'm using an Autel MD806 Pro
I believe the speedometer sensor is internal to the transmission tail section and I believe the wires for that sensor go through the transmission to the TCM, which is on the valve body...if true that would suck...if someone knows about this 5 speed transmission and its speedometer sensor, please enlighten me.
And if any of you work on Nissan/Infiniti auto transmission let me know is those numbers are normal or not....thanks.
or if someone with a g35 auto and have a scanner that does live data from the Transmission module can you look and see what your numbers are. please :-)
