1) Main sender is 3~80 ohms F -> E, sub sender is 3~43 ohms. Note that the behavior you describe can be from a bent arm, sunk float, stuck or tangled float arm on
either sender, not just an electrical issue. See Pp 18 of this ESM section for more info:
https://www.nicoclub.com/service-manual ... 5%2Fdi.pdf
2) There's no assembly, the parts are all separate. Here's the rundown:
Tank Seal Ring - 17342-CE800
Pump w/ Pickup Screen - 17042-AC700
Rubber Pump Support - 17043-4M405
Pump Bracket - 17012-8H300 (Discontinued)
Level Sender - 25060-AM600
Temperature Sensor - 22630-5S700
Filter - 16400-2Y505
Filter Packing - 17044-4M405
Filter Clip - 17571-2Y50A
Filter Seal Ring - 17049-4M400
Regulator Seal Ring - 16618-2Y501
Regulator - 22670-8H300
