2005 G35 replacement bulbs
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
jza80king
Car: 1992 Nissan 240SX
1998 Toyota Supra Turbo
So I searched on here and was able to get info on how to change out the headlight bulbs, and I did find out the OEM bulb is HID-D2R but I was wondering would it be just as good to get a bulb from autozone? Say a Silvania Silverstar? I believe the H1 or 9003 is the bulb can anyone chime in?
pfarmer
Car: 2008 GXS with technology package
jza80king wrote:So I searched on here and was able to get info on how to change out the headlight bulbs, and I did find out the OEM bulb is HID-D2R but I was wondering would it be just as good to get a bulb from autozone? Say a Silvania Silverstar? I believe the H1 or 9003 is the bulb can anyone chime in?
You just may want to do a search on the Internet and see what the difference between HID-D2R and H1 bulbs actually is.
Perry
gnvenom
Car: 2006 G35 Coupe
D2R is an HID Xenon arc lamp. The H4 is a standard halogen bulb, they are not compatible. The arc bulb requires a ballast (and you shouldn't have to replace it unless it's broken) - the bulbs last almost forever.
The H4 is a filament bulb. Don't even think of replacing an HID with a filament lamp.
D2R is a standard HID lamp with light shield paint applied to the bulb housing. The D2S is the same bulb without the shield paint.
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
+1Part number for bulb at dealer is 26297-7S600 or 26297-89910. same thing.
Guju Rider
Car: 2004 Infiniti G35 Desert Platinum (Sedan)
i have original OEM infiniti g35 D2R bulbs rated at 4100k which i took off my car that im willing to sell you if you want..just let me know..they are just sitting in my room.
and if you want..i can send you some easy instructions to replace the bulbs in your driveway if you need them.
jza80king
How much?
Guju Rider
$60...(paypal)
jza80king
each or the pair? do they fit the high or low beam? sorry for not knowing anything but its for a buddy's car
Guju Rider
that is for both bulbs and they fit the low beam part of the headlight.
Return to “G35 and G37 Interior, Exterior and Audio”
