2005 G35 rear shelf removal help.
IvanM
Car: 2005 G35 sedan
Hello everybody! I am new in this forum, but already found a lot of usefull info for my new toy:). Need a help with removing the rear shelf, I started but realized that I need to remove the side panels and the rear seats. I need to remove the shelf in order to remove the tint adhesive which I can not reach because of the stop light on the shelf. Please help if anybody have done this before.
Modified by IvanM at 9:47 AM 12/20/2006
G_whizz
Car: 2010 G37 Coupe Sport
Hey Ivan...Welcome to NICO!
Good to hear you have found it helpful so far! Is your new toy a Coupe or SedanI'm not sure how to remove the rear shelf, but I'm sure someone here will be able to assist you!
infinititech1
ok well this could be easy or hard for you...if u have a coupe...its going to be easy, if you have a sedan it'll be a little tougher. in the coupes the 3rd brake light basically just pops out of place...but on the sedans its connected to the shelf..which one you have?
IvanM
Car: 2005 G35 sedan
sedan..... ....I am trying to find 2005 INFINITI G35 SEDAN SERVICE MANUAL online, I guess I will heve the info there....
psedog
Car: 2006 G35 Sedan
IvanM wrote:sedan..... ....I am trying to find 2005 INFINITI G35 SEDAN SERVICE MANUAL online, I guess I will heve the info there....
Here you go http://www.psedog.com/G35_hosted_files/ ... ual/ei.pdf It's on page 40
IvanM
Car: 2005 G35 sedan
Thanks! This helps a lot but if you have the pdfs for the following steps it will help 100%
"REMOVAL1. Remove rear seat. Refer to SE-98, "Removal and Installation" .2. Remove rear seat back center finisher. Refer to SE-98, "Removal and Installation" .3. Remove rear seat belt floor anchor bolts. Refer to SB-5, "Removal and Installation of Rear Seat Belt" .4. Remove rear pillar finisher. Refer to EI-39, "BODY SIDE TRIM"."
I checked your audio instalation - interesting. Maybe in the future I will improve a little bit the audio in my sedan /the mids are not enough, the highs are too much and not clear...- I have the base system like you do/. Do you have a better sound now in yours?Thanks again;)
WESIDE
Car: 2006 g35 coupe
sorry to thread jack but anyone here have the service manual for the 06 coupe?
IvanM
Car: 2005 G35 sedan
