What youre' missing here is that you should determine why the camber is off. Going to aftermarket arms may band-aid the static camber issue, but can cause other issues and/or have poor dynamic camber angles, which can cause more serious problems. I mean, if you want to buy adjustable arms then feel free, but don't look to that as a solution to a camber problem that shouldn't exist. It would be another story if you were correcting camber as a result of lowering the vehicle...Busta Nut wrote:Wow, thanks for the response!
No, the car has not been lowered. Bought brand new in Feb. 06, and never wrecked. With 45,000 miles, I am about to do the third set of new tires, and they're wearing on the inside.
I really like those Cusco A-arms and they look alot cheaper than the Stillens............thanks again. I'll let you know how thery work and post some pics!
awdjdmtalon wrote:I just did the alignment on my G35. I always check the illustrations for the procedure before I start. And for our cars there "Is no camber or caster adjustments" for the front end per manufacturer.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
