2005 Frontier with Trans Issues.
no1pony
Hello everyone,
New to the site and I have a transmission interchange question for my 2005 frontier. Like many of you I had the coolant contamination issue with this truck. I caught it right away and did all I could reasonably do to get all the coolant out of there ASAP. I have driven this truck daily about 70 miles a day for the last 9 months or so without any real issues until last week. Lat week the transmission sent a p1764 code and immediatly went into failsafe mode. I drained and replaced the fluid and filter and it drove great for 20 miles or so then same thing. My theory on this is that the TCM over time has become corroded inside from the coolant and is malfuntioning once it heats up. I put an ohm meter on the solenoids and get a reading of 7 my understanding is that is good since they should read between 3-9.
After doing a ton of searching I have learned that I am not going to find a remanufactured body with all the electronics on it so I am looking for a used Transmission. I know that the 2005 frontier share the trans with the xterra but are they the same? my trans has a tag that says 97X0B. If anyone has any info on other transmissions that will work in my truck or any relative valve body info it would sure be helpful. my truck is an 05 4x4 kingcab with the V6.
Thanks
