oldcuss »
https://forums.nicoclub.com/oldcuss-u87416.html
Tue Jan 29, 2008 5:54 pm
My 05 crew cab, without factory tow package, I added reese hitch, then installed factory jumper harness with 2 relays for A/T behind passenger kick panel, then I installed factory 7 way camper wiring harness...upon checking 7 way plug in with a voly meter, i have no ground at pin one ( std wiring diagram ) and no tail light voltage at pin 3.....I replaced the jumper relays , checked all the fuses and connectors to the harnesses even put in the 3rd relay in the jumper harness even though it says it's not needed for A/T...What am I missing, I can cut into the factory 7 way harness and rig a ground and also rig a tail light circuit but thats the reason I spent almost $90 on the factory parts, I dont want to just rig it...Please help me if you can.... Thanks in Advance.. Gene
