2005 Frontier Nismo Transmission Fluid Change
Gorhad
Car: 2005 Nismo Frontier
2005 Mercedes SLK 350
2004 Dodge Ram 1500
2004 Infiniti G35
Hi all, Iver just done the Transmission oil/radiator cooling system by pass on my sons 2005 Frontier Nismo
Also drained the transmission fluid and installed new filter etc
Completed it to find i still have the same problem.....1st to 2nd gear change up a bump all other gear changes up and down are fine. Then as i come to a stop 2nd to 1st change down a bump. No cross contamination of fluids at all. Question is going front to rear under the truck just backward of the transmission and pan about a foot or so is the drive axle that has some sort of mount on it, the top portion isnt connected to anything i have no clue of its value there could it be the mount is gone bad causing the thud
Many thanks
Gorhad
2004 Dodge Ram 1500
2004 Infiniti G35
Anyone????
I tried to find a frontier on walmart carpark today to crawl under ....but got scared incase they thought i was a thief lol
