NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sun Apr 03, 2005 2:13 pm
it would be quite expensive to get all the control units to do it. it uses the IVMS on the ignition switch which is not cheap you would also need the BCM which is even more expensive. And quite possibly the ECM as all 3 communicate to determine weather or not to send a ground to the ECM relay to turn on the vital functions of engine control portion of the ecm. you would be better off at this point if your didnt buy the car with the system to get an aftermarket one you could get and have it installed for much less then the price of the IVMS
