2005 Frontier Factory Stereo Removal
roscoe_2005frontier
Can someone help me? I want to put some subs in my Frontier. Does the factory radio have the RCA pre-outs on the back? Also, can someone tell me the steps required to remove the radio from the dash? I don't want to screw things up.
transporter
Car: 91 240sx / 01 Infiniti I30 / 05 Frontier
It is pretty easy to pull out the radio in the frontier. You have to pull off the surrounding cover. I don't think mine had any screws in it. It simply popped off with a screwdriver wrapped in a tee shirt to keep from marking up the dash. Once it is popped off there are 4 screws that hold the radio assembly in place. I have the Rockford Fosgate edition radio and it does have the outputs for an amp. All that I installed was a Sirius radio.
One note. The space behind the radio is kinda tight so be careful with adding cables. If you pinch them you could cause all kinds of damage.
Transporter
