Bit of background, car burst radiator and got quite hot, fixed rad and all seemed fine, fast forward exactly 3 weeks and stalls at the lights, not hot or anything but very hard to start and missing like a mofo.
So wondering, did a sensor get cooked? Was no engine light or anything until the next day when I started it again now engine light, slip and vdc are lit.
I can still drive but very difficult.
Takes ages to start but when it does it idles mint
Misses like crazy when trying to drive but (hard to explain) if you guess where the throttle should be for the gear/speed you are doing it seems ok but the slightest movement outside that and it's like coils breaking down super bad, i'd so firing on 3-4 cylinders only. If you try rev when sitting in park, like try to hold at 2-3k and it revs up and down like you are revving it.
What do you think issues is?
