marctronixx »
https://forums.nicoclub.com/marctronixx-u191356.html
Sat Jun 17, 2017 12:02 pm
well, have you had your thermostat on the engine changed?
was the coolant low?
do you have any coolant leaks?
did your "mechanic" check for any code at the obd port?
how long have you had this car? is a "new to you car"/purchased used or have you had it for a while?
if you started the car from COLD and drove "about a mile" the engine would most likely NOT be at full operating temp, but this can change depending on how long you idled before driving off, was the car actually not at COLD (i.e. it was sitting for a few hours).
was this the first time this happened?
can you reproduce this each and every time?
if its electrical in nature, could be a faulty block temp sensor/electrical. if that is the case there could be a code at the obd port.
your "mechanic" just stating "the engine was not hot" is not a good diagnosis.
