2005 Altima SER won't rev pass 3000 rpm
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
rdb2017
Car: 2005 Altima SER
Hi guys,
This is how I fixed mine. First I replaced the throttle body, crank position sensor and cleaned map sensor but still the same.
Finally after a week I dediced to clean the IAC( Intake Air Control) valve with Throttle Body Cleaner and the car runs fine and goes
over 3000 rmp now up to 4500 and doesn't die in tropic stop light anymore. Hope this helps someone before spending money.
Also if your rpm goes up and down, you need to do the relearn procedure.
ca18det_boy
Why didn't you clean the idle air control valve first? Would have been cheaper than replacing all those parts. I'd take a $4 can of cleaner any day over replacement parts.
Return to “3rd Generation Altima Sedan (2002-2006)”
