2005 Altima SER AC drain hose
General discussion area for the L33-chassis Altima.
Mister_Lizard
Car: 2005-Altima-SE-R
Hello! i have been trying to find my AC drain hose and i cannot find it. i have crawled under the car a couple times now and looked for quite a while with no luck :frown: . i have tried using the diagram on page 8 http://www.nicoclub.com/FSM/Altima/2005 ... ma/ATC.pdf but still could not find it. The only thing i haven't done is jacked the car up as i currently don't have jacks. If anyone could help out and tell me where it is that would be great.
PapaSmurf2k3
Site Admin
You're probably going to have to jack it up or put it up on ramps to see/get to the hose. It should be located somewhere around the bottom of the firewall/near the bottom of the firewall/floor.
Mister_Lizard
Alright i borrowed my friends jack and i looked around and was unable to find it :bs: i checked all around the firewall where i could see many other rubber hoses coming out but none of them were lose when touched or facing down. i just can't believe that i couldn't find it.
EDIT: i found it on the inside of the car and doesn't seem to be clogged so i guess there mite be something else wrong with my ac.
Return to “5th Generation Altima Sedan (2013-2018)”
