2005 Altima 3.5SE rear rotor+ brake job
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
javahooked
Car: 2005 Nissan Altima 3.5SE
Hi, I am newb here. Any help would greatly be appreciated. I had changed my front rotors and brakes few months ago without a problem. Yesterday I started to jack up the car as I wanted to change my rear rotors and brakes. Disengaged the E brake to be sure and removed the rear tire. Looking at the rotor I noticed its not really identical to the front rotor. There was a feature between the Lug nuts almost like a giant set screw (retaining screw??). I have never seen this before. Also the new Rotors I bought from Advanced auto parts does not have this feature.The bottom nut of the brake caliper is blocked by a bar going at an angle. Can I just use a open socket wrench to removed the brake caliper?
thank you in advance
digitalbow
Car: 2003 Nissan Altima 3.5T
Andrew224
Car: 2001 Infiniti QX4
2006 Maserati GranSport
2002 Harley Davidson VRod
That video was a great help! I was attempting to do a rear brake job on my girlfriend's mom's car and had a hell of a time with the rear rotors. I was about to give up when I decided to check the board here. (I'm a regular on the M45 and QX4 boards). Funny, it was right at the top, I didn't even have to search!
Great tactic. Very much appreciated.
Andrew
javahooked
Hi,thank you so much for posting the video. I tinkered for an hour and a half before giving up. I will try that trick with the jack to take the rotor off.
Return to “3rd Generation Altima Sedan (2002-2006)”
