2005 350 Z Brake Problems
Nissan 350z / Nissan 370z general community discussion forum
springerdan1
Car: 2005 Nissan 350Z
I am new to the forum, so forgive me if this topic has been exhausted already, but I have been having problems with my rotors and pads on my 2005 350Z. Mileage was at 18,000 when I first experienced a bad metal to metal wearing noise, and high level of squealing noise during normal driving. The dealer replaced the front rotors and pads and the noise disappeared for a while, now it is back and the brake warning light stays illuminated at all times.
I get the impression the brakes were unspec'ed and I was thinking of installing a set of high performance Brembo calipers, brakes. Has enyone else experienced brake problems? Is anyone installed Brembo calipers/brakes and if so what is your assessment?
R350Zz33
Car: 2008 350z enthusiast
i have the same problem i have an 08 all stock i dont have the light coming on but nissan fixed it once at 3,000 miles came back the other day. i have an idea of what it might be i will try and fix.let u guys know what hapeans
spitalul2bad
Car: Nissan 350z Roadster - REV-UP Engine
Opel Vectra C
BMW E30 6cylinder 2000cmc
did you check the brake fluid? is it leaking?
R350Zz33
mines fine
ldstang50
Have you even thought to check your rear pads? You said they replaced your fronts only.There's a thread on here about the rear brakes wearing before the fronts. Search and you'll find it.
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
Need to down shift and save those brakes guys... check your back brakes or have them replaced as well just went thru the same BS on my girlfriends car. I changed her brakes (she insisted on cheap ones) they started squeaking and got warped in no time. So she wanted them replaced with better front brakes, i told her i should look at the back brakes (drums), and i she turned down the idea because she didn't want to spend the money - which now she complains about how she has brand new really good brakes but she hears the squeaking from the back brakes now and the brakes only feel a tiny bit better, which is because the drums need done which will get done when she wants to fork out the cash..... P.S. i rent a caliper tool kit from advanced for $100 which you get a full refund when you return it, but this kit reduces my brake changing time dramatically! I changed her brakes the last two times in my driveway in 20 mins from start (jacking the car up) to finish (pumping the brakes when finished).
Watermelonwarrior
Car: 2006 Cayman S 6SPD
rmezz13 wrote:Need to down shift and save those brakes guys...
I don't know about you guys but I rather use up brakes then clutch...
albert_ey
Car: 2007 Nissan 350Z
I agree! haha, I'd rather replace brakes than have to drop the transmission any day.
Down shifting sure is fun though. Right Richie? haha, just messin
Retired Chief
I down shift but only when cornering so I’m at a better RPM when I come out of the turn. I’m unaggressive about it too, not causing the engine to scream at a high RPM when I release the clutch in the lower gear. I don't down shift as I'm approaching a red light or stop sign. There's no reason to. But, I agree, it’s cheaper to replace brakes than it is a transmission/clutch.
Watermelonwarrior
Retired Chief wrote:I down shift but only when cornering so I’m at a better RPM when I come out of the turn.
You mean you down shift before the turn...
I agree I also downshift when driving "spirited" but I don't down shift to slow down. Thats what the brakes are for.
Retired Chief
Watermelonwarrior wrote:You mean you down shift before the turn...
Correct. I don't down shift in the turn.
Ender_Zero
Car: '03 Base Z, '91 S13 Coupe
You guys might call it lame, but I've gotten the habit of downshifting about 80% of the times I slow down. I don't aggressively downshift unless I'm driving hard, though. It makes me feel like I'm getting to know the car better by learning how to rev match and heal-toe in any situation. I use the experience when I do any kind of Auto X or fun in a parking lot or getting on the track. It doesn't use up the clutch too bad if you are good at matching revs.
Return to “350z / 370z Discussion”
