Llarion »
https://forums.nicoclub.com/llarion-u199629.html
Thu Mar 01, 2012 7:26 am
Hi there!
My 2005 3.5SE runs great; but in the last 30-60 days, I've noticed an odd behavior. When the engine is dead cold, the first start of the day or on the way home from work, it has to crank longer than it used to, like 1.5-2 seconds. It's like it's hesitating for a second before catching. Once it has run, even for a minute, it the catches immediately, like brand new. I did a B&G gas additive at the last oil change to remove water from my fuel system; my regular mechanic suspected it might be that; and that did indeed help but only for a couple of days. It's almost a non issue because it always starts, but it's different enough from that way it behaved for 6 years that I'm a little suspicious.
In thinking about what else it might be, I came up with the following hypotheses:
1) Fuel pump failing - when cold, it's taking longer to get it "primed" than it used to, so perhaps the pump is weakening but still functioning.
2) Ignition system - dirty spark plugs, perhaps, or a weakening ignition coil; but it seems like a problem like this would either manifest all the time, or even be a binary state (run/not run at all) in the case of a coil going bad.
3) Intake plumbing - I change my air filter regularly, but could the intake system be somehow gummed up in such a way that it would impact cold starting?
I'm under a really good extended warranty; it's essentially the factory warranty with a $50 deductible, but before I take it to the dealer; I wanted to have some learned opinions, since the problem is so minor as to possibly escape detection. I'm "retentive", so I notice. And I'm a little paranoid that if it's the fuel pump, that it will one day just strand me; so I wanted to head it off at the pass proactively.
Any thoughts or insights would be greatly appreciated! Thanks in advance!
