2004 z no start.
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
Luke
Car: 2004 350z
Just bought a 2004 350z convertible ran fine for a month now squeals in engine compartment , probably tensioner but now can't get car to crank, new battery, will check all fuses in the morning?
Lost ??????
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Welcome to NICO!
Squeals are not normal, if it's just a belt squeal it's likely unrelated to your no start issue.
It could be as simple as the starter, or a battery cable but there are more possibilities depending on if it's a manual or automatic. Being convertible I'll assume auto. Neutral safety switch could be at fault, if it's a manual the clutch safety switch or even the rubber grommet it contacts could be at fault. Could also be a security issue, what does the security light do? How about all your other electronics? Everything else working?
Luke
Car: 2004 350z
Yes it's automatic, all lights radio good, security light blinks when key out and off with key in, checked all fuses I could find (3 sets)
How would I check the neutral switch and the starter ?
Right before it quit working the starter seemed a little hesitant so afterwards I got a new battery - not cheap I might add.
Thanks for the reply hope to get this narrowed down soon
evildky
06 Nissan 350Z GT
If it seemed hesitant before and a new battery didn't improve things it's most likely the cable or the starter, you can take the starter out and to most parts stores where they will test it for free. Before pulling it make sure the power and ground connections are good at both the battery and starter.
Luke
Car: 2004 350z
Thanks for the advice
Fi you know if I power check the starter cable (to see if it's getting power)
Would be 3 - one to battery, negative, and starter switch? Then would I have to have ignition turned to see power going to it?
All of this done from under car driver side ?
evildky
06 Nissan 350Z GT
Just make sure the cables at the battery are terminated securely and no loose, make sure the other end of the cables is also terminated securely and not loose. the starter does need to be removed from the bottom.
Luke
Car: 2004 350z
Thanks for the good advice got a starter for 54.00 and fired right up, now to figure what belt or tensioner is squealing
Return to “350z / 370z Technical”
