C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Thu Sep 18, 2008 11:22 am
The front brakes were an issue. Nissan increased the amount of rotor material in updated rotors to reduce the problem. For the most part, it has alleviated the issue.
The rear diffs can be an issue. The spider gears in the diff have been known to break. Make sure, the TSB has been done at the least. I haven't bothered with it, but I plan to get a true-trak at some point (which eliminates the spider gears completely).
As for the tailgate, I bought an Easy-Lift for it and it works wonderfully. I can lift mine with one hand. Its nothing more than a torsion bar. It does require you to drill into the bed and tailgate, but is pretty inconspicuous.
The passenger seat might run into issues. Particularly with the captain's chairs. They may sway side to side. There is a TSB for the manual ones and the fix is to put loc-tite on certain screws and bolts and retighten. I have the electric seats and it had the same problem. Similar screws came loose and tightening them fixed the problem just fine.
